37-62 restoration
Well I'd thought I'd seen everything, but was not prepared for this:
[Image: http://i1365.photobucket.com/albums/r745...klszyj.jpg]
A good lamp base in a 37 Philco.
John
Las Vegas, NV USA
37-62 restoration - by LASJayhawk - 11-27-2015, 11:44 PM
RE: 37-62 restoration - by LASJayhawk - 11-28-2015, 06:42 PM
RE: 37-62 restoration - by LASJayhawk - 11-28-2015, 11:59 PM
RE: 37-62 restoration - by LASJayhawk - 12-06-2015, 01:20 PM
RE: 37-62 restoration - by mikethedruid - 12-06-2015, 05:14 PM
1 - 0v - correct 2 - 0v - correct 3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being o...morzh — 05:15 PM
