Philco Model 048 all purpose set tester
There is one other thing--along with the 22.5, I think the rig takes a couple of D cells as well.
Re: Philco Model 048 all purpose set tester - by batterymaker - 04-08-2009, 02:55 PM
There are currently 3079 online users. [Complete List]
» 1 Member(s) | 3078 Guest(s)
