Philco Model 048 all purpose set tester
That would be two D-cells in parallel for the 1.5 volt filament, as shown, for the number 30 tube, I assume.
Re: Philco Model 048 all purpose set tester - by Chuck Schwark - 04-08-2009, 03:53 PM
There are currently 3916 online users. [Complete List]
» 1 Member(s) | 3915 Guest(s)
