Strip and finish, strip and finish, strip and .....
After six frustrating years of trying to achieve a nice finish on my late version 116, I’ve finally finished. I must have stripped and finished, stripped and finished, probably five times over the years before it came out looking the way I wanted. It’s a fantastic performer with a dead-on dial and for the time being will keep the 8” PM speaker that I put in years ago. The photo doesn't do it justice.
Oddly, I couldn’t align the IF to 460 KHz, nor 465. It only wanted 470 KHz so that’s where it stays. Being that this is the very last 116 model and somewhat scarce, I wonder if Philco production techs didn’t use IF transformers from the 1937 series.
Pete AI2V
There are currently 10287 online users. [Complete List]
» 1 Member(s) | 10286 Guest(s)
