38-690 volume control
(12-07-2015, 11:13 PM)Chuck Schwark Wrote:  Looking for the values of the dual-pot volume control on the Model 38-690.
All Philco service bulletins and 1937-40 Philco parts catalogs do not show the resistances
of the two sections.  Only the Philco part number:  33-5240.
Seems Philco never published parts values in their 38-690 service bulletin.
Any help appreciated,
Chuck
Hi Chuck,
While the parts list does not show the values, they are printed on the schematic as part #75 at 500K and part #76 at 100K.
BTW, keep up the good work. I have your data package for my 38-690 code 125 and it has been invaluable.
Thanks again!
Ed
38-690 volume control - by FStephenMasek - 12-07-2015, 03:11 PM
RE: 38-690 volume control - by Chuck Schwark - 12-07-2015, 03:40 PM
RE: 38-690 volume control - by Chuck Schwark - 12-09-2015, 10:22 AM
RE: 38-690 volume control - by SteveJB - 12-18-2017, 08:42 AM
RE: 38-690 volume control - by morzh - 12-18-2017, 09:21 AM
RE: Resistance values for 38-690 vol pot - by etech - 12-08-2015, 07:11 PM
RE: Resistance values for 38-690 vol pot - by sam - 12-09-2015, 11:50 AM
The speaker table error?
Philco 70 antenna lead
