38-116 broken wire in sub-chassis
Update on the 116.
Got another 6r7 and tried it.
Did not help.
After it warms up a little the sound quality still diminishes and gets distorted.
If I increase the volume, it gets a little louder and along with increased volume comes the distortion.
Something is wrong in the audio side.
If the output tranny was going out, would this happen?
Or,is it a matter of working or not working?
Any chance it could be a speaker related problem?
Pulling my hair out on this one.
murf
38-116 broken wire in sub-chassis - by murf - 11-29-2015, 12:50 PM
RE: 38-116 sub-chassis removal - by klondike98 - 11-29-2015, 01:47 PM
RE: 38-116 sub-chassis removal - by Ron Ramirez - 12-01-2015, 09:55 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-01-2015, 11:30 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-02-2015, 05:33 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-02-2015, 09:30 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-03-2015, 06:24 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-03-2015, 11:09 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-09-2015, 07:23 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-09-2015, 09:47 PM
38-116 question - by murf - 12-01-2015, 09:17 PM
