38-116 broken wire in sub-chassis
Hi Terry,
Checked voltages on both 6L6 tubes and are as follows.
Tube 1
Pin 2 6.5 ac
Pin 3 220v
Pin 4 244v
Pin 5 -7.4v
Pin 7 checks 0 volts ac(should be 6.3)
Tube 2
Pin 2 6.5v ac
Pin 3 243v
Pin 4 244v
Tested both 6L6 tubes also,
Tube 1 checked 4000 (mut cond = 5000)
Tube 2 checked 3500
Pin 5 -31.6v
Pin 7 checks 0 volts(should be 6.3)
High voltage a little low
6.3 ac missing on pins 7
Irregular voltage on pins 5
Tubes check low on my hickok tester.
What do you make of this?
murf
38-116 broken wire in sub-chassis - by murf - 11-29-2015, 12:50 PM
RE: 38-116 sub-chassis removal - by klondike98 - 11-29-2015, 01:47 PM
RE: 38-116 sub-chassis removal - by Ron Ramirez - 12-01-2015, 09:55 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-01-2015, 11:30 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-02-2015, 05:33 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-02-2015, 09:30 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-03-2015, 06:24 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-03-2015, 11:09 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-09-2015, 07:23 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-09-2015, 09:47 PM
38-116 question - by murf - 12-01-2015, 09:17 PM
There are currently 5515 online users. [Complete List]
» 1 Member(s) | 5514 Guest(s)
