Anyone suggest a good speaker re builder?
I have a philco jr speaker in excellent original condition but it has a voice coil rub. Can anyone on here suggest a speaker rebuilder-service shop that does good work and is familiar with these type speakers.
Thank you
There are currently 5445 online users. [Complete List]
» 1 Member(s) | 5444 Guest(s)
