Rehabilitating a Cardboard Back
I spent two hours bending and painting a little piece of metal to simulate a T-clip.
[Image: https://lh3.googleusercontent.com/-bEtlu...252038.JPG]
If I had known about Renovated Radios, I would have spent the 75 cents.
Thanks.  I'll add them to my list of suppliers.
Rehabilitating a Cardboard Back - by Winky Dink - 11-19-2015, 05:34 PM
RE: Rehabilitating a Cardboard Back - by Squire - 11-19-2015, 05:48 PM
RE: Rehabilitating a Cardboard Back - by VntgRads - 11-19-2015, 08:43 PM
RE: Rehabilitating a Cardboard Back - by sam - 11-29-2015, 07:06 PM
RE: Rehabilitating a Cardboard Back - by LET-UT - 12-08-2015, 06:26 PM
RE: Rehabilitating a Cardboard Back - by Winky Dink - 12-14-2015, 01:59 AM
There are currently 10374 online users. [Complete List]
» 2 Member(s) | 10372 Guest(s)
