Philco 89 Volume Control and DeOxit
Good chance the De-Ox-It dissolved some grease or oil in the
shaft bushing and spread it around the carbon track and wiper
causing dead and intermittent spots.
Chuck
RE: Philco 89 Volume Control and DeOxit - by Chuck Schwark - 12-17-2015, 10:07 AM
1 - 0v - correct 2 - 0v - correct 3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being o...morzh — 05:15 PM
