Philco 90 questions
As it seems requests for an under-chassis view of a Model 90 is coming up fairly regularly, here is a picture I took a few months ago of an unmolested original 90 with single 47 output:
[Image: http://i326.photobucket.com/albums/k420/...nder90.jpg]
Click the thumbnail above to see a full size picture.
Philco 90 questions - by garyh1 - 04-12-2009, 08:55 PM
Re: Philco 90 questions - by Ron Ramirez - 04-12-2009, 09:07 PM
Re: Philco 90 questions - by garyh1 - 04-12-2009, 11:16 PM
Re: Philco 90 questions - by Ron Ramirez - 04-12-2009, 11:53 PM
Re: Philco 90 questions - by Texasrocker - 04-16-2009, 03:59 AM
There are currently 9942 online users. [Complete List]
» 1 Member(s) | 9941 Guest(s)
