Trying to figure the production run on a 620B
Hey guys,
Getting ready to perform an electrical restoration on a 1935-1936 Philco Model 620B.  I am really having a troubled time trying to figure out the production run number.
The tag is below.  It looks like 1 - 4 but I don't really know what that means.
Thanks for the help.
Jon
"A Minute of Care is Worth an Hour of Repair" circa 1930.
Trying to figure the production run on a 620B - by Philco281989 - 12-18-2015, 03:26 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7095 online users. [Complete List]
» 1 Member(s) | 7094 Guest(s)
