Trying to figure the production run on a 620B
Well you're in luck.  Service Bulletin 218-A, for the later production runs of the 620,
beginning with Run No. 7, shows the circuit you have with the 3-section resistor
in the power supply section.
Happy Holidays!
RE: Trying to figure the production run on a 620B - by Chuck Schwark - 12-18-2015, 09:02 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
