RCA C15-3 floor model
This is a new find, was not aware of another on ARF. 1936 is no doubt the correct year and was a little puzzled when two radio books and nostalgiaair schematic said 1935. Must admit RCA is not among my favorites of radio brands. The lady advertised it as a 1940s radio for $100. Called just in case the owner was mistaken, not a big fan of 40s radios. When she emailed me the pictures I was floored and did not quibble over the price. This is my highest tube count radio and first to be factory fused. Thanks for your comments.
Richard
RCA C15-3 floor model - by rghines1 - 04-12-2009, 06:05 PM
RE: RCA C15-3 floor model - by rghines1 - 03-14-2021, 09:38 AM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-14-2021, 10:47 AM
RE: RCA C15-3 floor model - by mikethedruid - 03-14-2021, 10:56 AM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-14-2021, 11:03 AM
RE: RCA C15-3 floor model - by morzh - 03-14-2021, 12:36 PM
RE: RCA C15-3 floor model - by rghines1 - 03-14-2021, 01:05 PM
RE: RCA C15-3 floor model - by rghines1 - 03-14-2021, 01:55 PM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-14-2021, 02:34 PM
RE: RCA C15-3 floor model - by Brad Winder - 03-17-2021, 12:22 AM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-17-2021, 08:58 AM
RE: RCA C15-3 floor model - by Arran - 03-17-2021, 07:42 PM
Re: RCA C15-3 floor model - by Doug Houston - 04-13-2009, 01:34 AM
Re: RCA C15-3 floor model - by Texasrocker - 04-13-2009, 03:53 AM
Re: RCA C15-3 floor model - by rghines1 - 04-13-2009, 10:02 AM
Re: RCA C15-3 floor model - by exray - 04-13-2009, 11:56 AM
Re: RCA C15-3 floor model - by Doug Houston - 04-13-2009, 03:13 PM
Re: RCA C15-3 floor model - by Arran - 04-24-2009, 10:02 PM
Re: RCA C15-3 floor model - by Arran - 04-24-2009, 10:36 PM
There are currently 4418 online users. [Complete List]
» 1 Member(s) | 4417 Guest(s)
