42-1015 Crashing Sound
Are there any silver-mica caps on the IF transformers?
42-1015 Crashing Sound - by davidff - 12-21-2015, 10:11 AM
RE: 42-1015 Crashing Sound - by Phlogiston - 12-21-2015, 12:00 PM
RE: 42-1015 Crashing Sound - by Sean - 12-21-2015, 05:22 PM
RE: 42-1015 Crashing Sound - by davidff - 12-22-2015, 10:01 AM
RE: 42-1015 Crashing Sound - by codefox1 - 12-22-2015, 03:52 PM
RE: 42-1015 Crashing Sound - by davidff - 12-22-2015, 04:46 PM
RE: 42-1015 Crashing Sound - by Sean - 12-22-2015, 05:18 PM
RE: 42-1015 Crashing Sound - by Arran - 12-23-2015, 06:18 AM
RE: 42-1015 Crashing Sound - by codefox1 - 12-23-2015, 02:51 PM
There are currently 6679 online users. [Complete List]
» 2 Member(s) | 6677 Guest(s)
