42-1015 Crashing Sound
Has the Cand-ohm bias resistor (item 91 on schematic) been replaced?  I have had these go intermittent in the past and cause the same sound that you describe.  I have made it a habit to replace these regardless of if they measure OK or not.
Sean
WØKPX
42-1015 Crashing Sound - by davidff - 12-21-2015, 10:11 AM
RE: 42-1015 Crashing Sound - by Phlogiston - 12-21-2015, 12:00 PM
RE: 42-1015 Crashing Sound - by Sean - 12-21-2015, 05:22 PM
RE: 42-1015 Crashing Sound - by davidff - 12-22-2015, 10:01 AM
RE: 42-1015 Crashing Sound - by codefox1 - 12-22-2015, 03:52 PM
RE: 42-1015 Crashing Sound - by davidff - 12-22-2015, 04:46 PM
RE: 42-1015 Crashing Sound - by Sean - 12-22-2015, 05:18 PM
RE: 42-1015 Crashing Sound - by Arran - 12-23-2015, 06:18 AM
RE: 42-1015 Crashing Sound - by codefox1 - 12-23-2015, 02:51 PM
There are currently 6729 online users. [Complete List]
» 2 Member(s) | 6727 Guest(s)
