RCA C15-3 floor model
1936 would be the correct model year but there's good odds it was actually manufactured in 1935. New year models typically hit the market in about September of the preceeding year. Sort of like automobiles.
Nice radio and an extremely good catch!
RCA C15-3 floor model - by rghines1 - 04-12-2009, 06:05 PM
RE: RCA C15-3 floor model - by rghines1 - 03-14-2021, 09:38 AM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-14-2021, 10:47 AM
RE: RCA C15-3 floor model - by mikethedruid - 03-14-2021, 10:56 AM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-14-2021, 11:03 AM
RE: RCA C15-3 floor model - by morzh - 03-14-2021, 12:36 PM
RE: RCA C15-3 floor model - by rghines1 - 03-14-2021, 01:05 PM
RE: RCA C15-3 floor model - by rghines1 - 03-14-2021, 01:55 PM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-14-2021, 02:34 PM
RE: RCA C15-3 floor model - by Brad Winder - 03-17-2021, 12:22 AM
RE: RCA C15-3 floor model - by Ron Ramirez - 03-17-2021, 08:58 AM
RE: RCA C15-3 floor model - by Arran - 03-17-2021, 07:42 PM
Re: RCA C15-3 floor model - by Doug Houston - 04-13-2009, 01:34 AM
Re: RCA C15-3 floor model - by Texasrocker - 04-13-2009, 03:53 AM
Re: RCA C15-3 floor model - by rghines1 - 04-13-2009, 10:02 AM
Re: RCA C15-3 floor model - by exray - 04-13-2009, 11:56 AM
Re: RCA C15-3 floor model - by Doug Houston - 04-13-2009, 03:13 PM
Re: RCA C15-3 floor model - by Arran - 04-24-2009, 10:02 PM
Re: RCA C15-3 floor model - by Arran - 04-24-2009, 10:36 PM
There are currently 8442 online users. [Complete List]
» 1 Member(s) | 8441 Guest(s)
