Fisher 700-T questions
Great! Working on that switch, and caps are on order...
Say, I can't tell from the schematic. Do you know what voltage the lamps get from the transformer? The dial pointer lamp needs to be replaced.
Devin
Fisher 700-T questions - by SolderSplash - 12-21-2015, 02:13 AM
RE: Fisher 700-T questions - by Ron Ramirez - 12-21-2015, 07:08 AM
RE: Fisher 700-T questions - by Ron Ramirez - 12-21-2015, 07:18 AM
RE: Fisher 700-T questions - by John Bartley - 12-21-2015, 08:53 AM
RE: Fisher 700-T questions - by SolderSplash - 12-22-2015, 11:14 AM
RE: Fisher 700-T questions - by SolderSplash - 12-28-2015, 07:52 PM
RE: Fisher 700-T questions - by Ron Ramirez - 12-28-2015, 08:04 PM
