Philco Lowboy 20 - restoring speaker
Hi. I am new here.
I have just bought myself a project - a Philco 20 Lowboy. Since sometimes there are different understandings of what it is - here s a link to it.
http://www.tuberadioland.com/philco20_co..._main.html
or our own gallery
http://www.philcoradio.com/gallery/1931a.htm#b , the picture of BABY GRAND CONSOLE (Model 20)
The speaker inside this radio is like this one:
http://www.radiolaguy.com/images/speaker...coSpkr.jpg
Well, the speaker happened to miss major part of the cone.
I spoke to Hank Brazeal, and he, having called this speaker "a big mistake by Philco" recommended first to check the field coil etc.
It does seem like the field coil exhibits 3050 Ohms of DC resistance, when check by a meter.
The transformer on the speaker does seem to have one winding showing 300 Ohms. Another one is in parallel to the voice coil, so I do not know whether it is OK, or ot is the voice coil, although I suspect it is OK (secondaries are usually thick wire, so it is not likely to break).
So I am almost ready to send it for re-coning, but here what I do not understand so far: the plug has 4 pins. However only 3 pins will be buzzed, and 4-th wire is unconnected. The there wired go to field coile and the secondary (mentioned 3050 Ohms and 300 Ohms, one pin is shared) and the 4-th one is soldered to a contact on the transformer but does not go anywhere.
This is not in agreement with the schematic that shows all 4 pins connected (field coil in series with transformer's primary centertap, both field pins connected and primary ends connected).
So unless I am mistaken one of the primary's ends is unconnected (broken>)
then I have another diagram from this website
http://www.philcoradio.com/tech/speaker.htm
Which shows the connection that would buzz exactly as what I have, and this is why I thought that maybe what I have is OK. But then it is nto for Philco 20. Or is it?
So, if anyone knows that speaker/xfmr connection - can you tell me whether you think my xfmr is shot or not? And can the speaker be restored after this or not?
Philco Lowboy 20 - restoring speaker - by Guest - 04-16-2009, 01:36 PM
Re: Philco Lowboy 20 - restoring speaker - by Guest - 04-18-2009, 11:30 AM
Re: Philco Lowboy 20 - restoring speaker - by Guest - 04-18-2009, 01:34 PM
Re: Philco Lowboy 20 - restoring speaker - by Guest - 04-18-2009, 01:38 PM
Philco 91 Restore Code ??
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
There are currently 2762 online users. [Complete List]
» 2 Member(s) | 2760 Guest(s)
