philco transitone tropic model 3010-123 schematic
grundigman3000
Try this - individual files of each page.
http://www.philcoradio.com/images/3010_pg1.jpg
http://www.philcoradio.com/images/3010_pg2.jpg
http://www.philcoradio.com/images/3010_pg3.jpg
http://www.philcoradio.com/images/3010_pg4.jpg
Not as high in resolution as the PDF but should work for you.
RE: philco transitone tropic model 3010-123 schematic - by Ron Ramirez - 12-27-2015, 10:21 AM
