M-22 Turntable Motor Question
Hi I just started working on a Philco C1340-121 Multi Speed turntable and had a question about the motor and whether I had a piece which might be frozen in place or of it is fixed by design.  Please see the attached photo and linked video.
Thanks for your help.
video clip at https://youtu.be/Kc-JuLvDJGo
M-22 Turntable Motor Question - by HungryFreaks - 12-27-2015, 06:43 PM
RE: M-22 Turntable Motor Question - by klondike98 - 12-27-2015, 10:25 PM
RE: M-22 Turntable Motor Question - by Arran - 12-28-2015, 03:47 AM
There are currently 5465 online users. [Complete List]
» 1 Member(s) | 5464 Guest(s)
