Resistence reading on Model 20 PT 2.5VAC
(12-24-2015, 08:07 PM)Radioroslyn Wrote:  <buzz primary to chassis
Methinks that's slang for measuring the resistance from the transformer primary to the chassis.
Terry, I found the source of my problem,. The CT for the 2.5V is open. I have another transformer I just compared it too and it shows the CT is there. Yes, the radio will work without the CT, but there is a hum and it is coming directly from the 27 audio tube. I have the transformer out of the radio and did a direct comparison to a known good transformer.
RE: Resistence reading on Model 20 PT 2.5VAC - by Tubesforme - 12-28-2015, 06:43 PM
There are currently 6511 online users. [Complete List]
» 2 Member(s) | 6509 Guest(s)
