37-61 rubber parts questions
I just checked my 37-61's cabinet, and what did I find still stuck in one front corner ? One of the mounting washers. Looks to actually be a Chassis Washer (CW4). I still would like to know if the Philco Chassis Front Spacers (GPH-spacer) is correct for my radio, as well as confirmation about the Chassis Washer (CW4). Any advice would be appreciated.
37-61 rubber parts questions - by mikethedruid - 12-28-2015, 06:19 AM
RE: 37-61 rubber parts questions - by mikethedruid - 12-28-2015, 07:19 PM
RE: 37-61 rubber parts questions - by klondike98 - 12-28-2015, 10:21 PM
RE: 37-61 rubber parts questions - by Phlogiston - 12-29-2015, 04:46 PM
