Philco Lowboy 20 - restoring speaker
Hi.
thanks for the reply.
yes I also thought so, especially in view of teh output being Class B Push-Pull.
However I called The Speaker Shop, and the guy there who knows Philco 20 speakers well, told me that it is correct that one of the 4 wires is unconnected, and it is there just in case for other versions, and the XFMR is without cenertap.
I am not sure how the Pushpull can handle a XFMR without centertap - it is a standard way of doing this; no centertap usually mean Class A amplifier would be used, not a pushpull.
I am confused. I don't think I'd have a wrong speaker arrangement in there, and I clearly see the chassis being Philco 20.
Philco Lowboy 20 - restoring speaker - by Guest - 04-16-2009, 01:36 PM
Re: Philco Lowboy 20 - restoring speaker - by Guest - 04-18-2009, 11:30 AM
Re: Philco Lowboy 20 - restoring speaker - by Guest - 04-18-2009, 01:34 PM
Re: Philco Lowboy 20 - restoring speaker - by Guest - 04-18-2009, 01:38 PM
