Philco 37-665B Restoration
As I said, both 6F6G tubes are very weak. The 6K7G is barely good. The 6A8G tube is bad. A 6C5 was subbed for a 6J5G. The Russians tubes are cheap and matched.
Rick Ethridge
Plattsmouth, NE
Philco 37-665B Restoration - by titan1a - 12-13-2015, 10:12 PM
RE: Philco 37-665B Restoration - by mikethedruid - 12-14-2015, 12:06 AM
RE: Philco 37-665B Restoration - by Arran - 12-14-2015, 01:52 AM
RE: Philco 37-665B Restoration - by klondike98 - 12-16-2015, 09:36 AM
RE: Philco 37-665B Restoration - by titan1a - 12-21-2015, 08:00 PM
RE: Philco 37-665B Restoration - by titan1a - 12-29-2015, 09:59 PM
RE: Philco 37-665B Restoration - by klondike98 - 12-29-2015, 10:23 PM
RE: Philco 37-665B Restoration - by titan1a - 12-30-2015, 01:11 AM
RE: Philco 37-665B Restoration - by klondike98 - 12-30-2015, 03:29 PM
RE: Philco 37-665B Restoration - by titan1a - 12-30-2015, 05:33 PM
RE: Philco 37-665B Restoration - by Eliot Ness - 12-31-2015, 11:32 AM
RE: Philco 37-665B Restoration - by klondike98 - 12-31-2015, 11:15 AM
RE: Philco 37-665B Restoration - by sam - 12-31-2015, 01:12 PM
RE: Philco 37-665B Restoration - by titan1a - 01-02-2016, 01:18 AM
RE: Philco 37-665B Restoration - by Arran - 01-02-2016, 02:40 AM
RE: Philco 37-665B Restoration - by titan1a - 01-02-2016, 09:39 PM
RE: Philco 37-665B Restoration - by mikethedruid - 01-04-2016, 10:24 PM
RE: Philco 37-665B Restoration - by titan1a - 01-05-2016, 12:46 AM
RE: Philco 37-665B Restoration - by titan1a - 01-05-2016, 12:10 PM
RE: Philco 37-665B Restoration - by mikethedruid - 01-05-2016, 04:31 PM
RE: Philco 37-665B Restoration - by titan1a - 01-14-2016, 03:05 AM
RE: Philco 37-665B Restoration - by sam - 01-14-2016, 04:04 AM
RE: Philco 37-665B Restoration - by titan1a - 01-14-2016, 04:42 PM
RE: Philco 37-665B Restoration - by titan1a - 01-18-2016, 12:48 AM
RE: Philco 37-665B Restoration - by mikethedruid - 01-18-2016, 01:41 AM
RE: Philco 37-665B Restoration - by Eliot Ness - 01-18-2016, 03:30 PM
RE: Philco 37-665B Restoration - by titan1a - 01-19-2016, 10:33 PM
RE: Philco 37-665B Restoration - by titan1a - 01-23-2016, 11:03 PM
RE: Philco 37-665B Restoration - by titan1a - 01-30-2016, 02:52 AM
RE: Philco 37-665B Restoration - by titan1a - 02-03-2016, 02:47 AM
RE: Philco 37-665B Restoration - by Arran - 02-05-2016, 02:06 AM
RE: Philco 37-665B Restoration - by titan1a - 02-14-2016, 11:29 PM
RE: Philco 37-665B Restoration - by titan1a - 02-22-2016, 11:18 PM
RE: Philco 37-665B Restoration - by titan1a - 02-28-2016, 12:01 AM
RE: Philco 37-665B Restoration - by klondike98 - 02-28-2016, 08:33 AM
RE: Philco 37-665B Restoration - by titan1a - 02-28-2016, 07:49 PM
RE: Philco 37-665B Restoration - by Mondial - 02-28-2016, 09:38 PM
RE: Philco 37-665B Restoration - by titan1a - 03-14-2016, 03:39 AM
RE: Philco 37-665B Restoration - by Fred Taylor - 03-14-2016, 07:26 AM
RE: Philco 37-665B Restoration - by titan1a - 04-03-2016, 03:12 PM
RE: Philco 37-665B Restoration - by titan1a - 04-04-2016, 12:50 AM
RE: Philco 37-665B Restoration - by klondike98 - 04-04-2016, 01:01 PM
RE: Philco 37-665B Restoration - by titan1a - 05-08-2016, 09:04 PM
RE: Philco 37-665B Restoration - by Mondial - 05-08-2016, 11:40 PM
RE: Philco 37-665B Restoration - by titan1a - 06-05-2016, 06:45 PM
Seen the light? - by titan1a - 12-16-2015, 01:40 AM
RE: Seen the light? - by mikethedruid - 12-16-2015, 02:59 AM
Users browsing this thread: 13 Guest(s)
