Zenith K731
Paul, I have a similar Z set the 12DT8 tube is a pain. I have had several NOS fail after maybe 50-100 hours  went to using 12AT7, ECC81 which are current production. The BIG DIFFERENCE is pin 9 on the ECC81 is center tap to the heater, on 12DT8 pin 9 is internal shield to ground. One must remove the ground connection from pin 9 of the tube socket or kiss your new tube good bye in a flash.
Zenith K731 - by Paul Philco322 - 01-03-2016, 06:51 PM
RE: Zenith K731 - by Phlogiston - 01-03-2016, 07:32 PM
RE: Zenith K731 - by Radioroslyn - 01-03-2016, 07:53 PM
RE: Zenith K731 - by Paul Philco322 - 01-03-2016, 08:58 PM
RE: Zenith K731 - by David - 01-03-2016, 10:01 PM
RE: Zenith K731 - by John Bartley - 01-03-2016, 10:05 PM
RE: Zenith K731 - by titan1a - 01-03-2016, 11:43 PM
RE: Zenith K731 - by VntgRads - 01-04-2016, 02:48 AM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6660 online users. [Complete List]
» 4 Member(s) | 6656 Guest(s)
AvatarAvatarAvatarAvatar
