41-285 Don't Know What To Do Next
Johnny, set the generator in the broadcast band not at your IF frequency, your canceling out. Try a mid range frequency or the frequency of the strong station you were getting. You use the IF frequency when you are aligning radio, another story for later. PL
41-285 Don't Know What To Do Next - by Johnny - 04-16-2009, 11:07 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 12:27 AM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 02:47 AM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 04:41 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 07:09 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 10:21 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-19-2009, 08:56 PM
Re: 41-285 Don't Know What To Do Next - by planigan - 04-20-2009, 12:40 AM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-20-2009, 11:54 AM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-20-2009, 03:35 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-20-2009, 07:45 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-21-2009, 02:20 PM
