Soldering Gun,Irons
Howdy:
I agree with the last post, in the the Metcal is an amazing unit, even at $800+. The extremely fast heat up (by RF skin effect) also results in very tight temp regulation - a tiny tip can therefore deliver MUCH more heat than others. I'm also fond of the hand held weller hot air blower $150 or so, versatile with paste flux, just keep it AWAY from plastic. My latest fave is a butane 'wind proof grill lighter' that has a 6-8 inch gooseneck-style tip. Sounds strange, but these are a real gem, delivering the equivalent of 200 watts - just enough to solder terminal strips to a chassis, but not light the insulation or rosin on fire (as a propane torch WILL). *BUT WAIT* - there's more! For the few times I need that kind of heat, the <$10 price tag is well justified, and will also enable some grilled burgers as well.
Until next time,
Stirling KC0NXM.
Soldering Gun,Irons - by dixierat - 04-17-2009, 05:09 PM
Re: Soldering Gun,Irons - by planigan - 04-17-2009, 06:17 PM
Re: Soldering Gun,Irons - by kruc - 04-19-2009, 06:19 AM
Re: Soldering Gun,Irons - by Guest - 04-20-2009, 10:41 AM
Re: Soldering Gun,Irons - by hollowstate - 04-20-2009, 10:59 PM
Re: Soldering Gun,Irons - by dixierat - 04-23-2009, 08:46 PM
Re: Soldering Gun,Irons - by codefox1 - 04-23-2009, 11:01 PM
Re: Soldering Gun,Irons - by Texasrocker - 04-27-2009, 01:27 AM
Re: Soldering Gun,Irons - by dixierat - 04-28-2009, 05:16 PM
There are currently 7072 online users. [Complete List]
» 2 Member(s) | 7070 Guest(s)
