81 Jr Cabinet Labels
Hi Bill,
Here are some pictures I saved from a recent auction:
You might be able to figure out the exact original sizes from marks on your cabinet and chassis.
81 Jr Cabinet Labels - by Bill Bacco - 01-09-2016, 10:02 AM
RE: 81 Jr Cabinet Labels - by Nathan Slingerland - 01-09-2016, 10:49 AM
RE: 81 Jr Cabinet Labels - by Bill Bacco - 01-09-2016, 11:06 AM
RE: 81 Jr Cabinet Labels - by Nathan Slingerland - 01-09-2016, 11:27 AM
RE: 81 Jr Cabinet Labels - by Nathan Slingerland - 01-09-2016, 11:33 AM
RE: 81 Jr Cabinet Labels - by klondike98 - 01-09-2016, 11:55 AM
There are currently 11046 online users. [Complete List]
» 2 Member(s) | 11044 Guest(s)
