41-285 Don't Know What To Do Next
Glad to be of help. It is great to hear that your 41-285 is working OK. Do you still have problems with the band switch? What is the cabinet like? My first Philco was a 41-280 that I still have. I bought it in working condition in 1982 but never dared to tear into it until a couple of years ago. I never would have if I hadn't gotten lots of help from the Internet, particularly this site and Phil's Old Radios that finally made me brave enough to try.
I think we were all misled by the fact that you picked up your strong local station when you connected your meter to the plate of the 1st IF. True, but a red herring. Once you verified that you couldn't get a tone with your signal generator on the 1st IF grid it was clear that normal servicing procedure was called for, not trying to diagnose the presence of that radio station. I think Norman Leal on the "other" forum called it correctly that you were just picking that signal up with your meter lead as antenna. What was so puzzling was that I wouldn't have thought the 1260 KHz signal would get through the 2nd IF stage since it is tuned to 455 KHz or that the 2nd detector would detect the audio from the 1260 KHz. I guess we all learned something!
I've been doing this a couple of years now. One of the first non-working sets I restored was a 40-150 that had been hacked by someone else. He cut out a bunch of wiring from around one of the IF tubes and hacked in a bunch of modern filter caps and left them and some other resistors and capacitors hanging in mid-air by some stiff wire, not connected to terminal strips. I had to cut out all that mess and figure out where the original wires and components went. When I had finished restuffing the original filter caps, recapping the wax caps, and replacing the rubber wires, I got nothing until I worked backwards from the speaker and realized that I'd left out the B+ wire to the plate of the IF tube. Once I figured out where that went, the radio finally worked. It is often a problem to pick up a restoration or repair where someone else left off. There is no good reference (that I've found) to tell you where all the original wires went.
I'm a big believer in the servicing techniques in "Elements of Radio Servicing." I recommend it all the time. You can get a .pdf copy of that book in six separate .pdf files at this site: http://antiqueradios.com/archive.shtml . It is really easy to follow. I read the whole book before I ever tore into a radio, and I refer back to it all the time.
I've gotten lots of help from this site over the last couple of years. Ain't the Internet great?
John Honeycutt
41-285 Don't Know What To Do Next - by Johnny - 04-16-2009, 11:07 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 12:27 AM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 02:47 AM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 04:41 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 07:09 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-17-2009, 10:21 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-19-2009, 08:56 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-20-2009, 11:54 AM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-20-2009, 03:35 PM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-20-2009, 07:45 PM
Re: 41-285 Don't Know What To Do Next - by Raleigh - 04-21-2009, 09:58 AM
Re: 41-285 Don't Know What To Do Next - by Johnny - 04-21-2009, 02:20 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 1931 online users. [Complete List]
» 2 Member(s) | 1929 Guest(s)
