Canadian model 37 3660???
Dan;
  I suspect that the 37-3660 should be in the RCC manuals, so if there are an differences between it and the U.S version it will show on whatever diagram they have in there. I don't have Canadian Philco service manuals for those years, I have a binder full of service folders spanning 1928-37 with the odd note made by my uncle about the Canadian near equivalents, such as tube changes or what the 25 cycle version was called. I can check to see if any note were made about a 37-660 and it's Canadian counterpart, but again the actual diagram will be in the RCC manuals.
Arrn
Canadian model 37 3660??? - by Dan Walker - 01-09-2016, 01:49 PM
RE: Canadian model 37 3660??? - by klondike98 - 01-09-2016, 02:14 PM
RE: Canadian model 37 3660??? - by Arran - 01-10-2016, 03:52 AM
RE: Canadian model 37 3660??? - by Ron Ramirez - 01-10-2016, 09:06 AM
RE: Canadian model 37 3660??? - by Arran - 01-11-2016, 05:24 AM
RE: Canadian model 37 3660??? - by Dan Walker - 01-11-2016, 10:58 AM
RE: Canadian model 37 3660??? - by Dan Walker - 01-11-2016, 04:53 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6192 online users. [Complete List]
» 1 Member(s) | 6191 Guest(s)
