  • 1 Vote(s) - 5 Average
Philco 89B headaches
Huzzah! That was it! Not only was the 51K up around 87K, but the 39K had decreased to 24K, so no wonder the screen voltages were high. Now that I've replaced those resistors, it's down around 87 volts, and the oscillator is oscillating.
Philco 89B headaches - by sparkydave - 12-22-2015, 06:35 PM
RE: Philco 89B headaches - by Ron Ramirez - 12-22-2015, 08:23 PM
RE: Philco 89B headaches - by markmokris - 12-27-2015, 12:41 PM
RE: Philco 89B headaches - by sparkydave - 01-04-2016, 08:59 PM
RE: Philco 89B headaches - by Phlogiston - 01-05-2016, 04:16 PM
RE: Philco 89B headaches - by sparkydave - 01-07-2016, 09:12 PM
RE: Philco 89B headaches - by Warren - 01-08-2016, 05:21 PM
RE: Philco 89B headaches - by klondike98 - 01-07-2016, 11:03 PM
RE: Philco 89B headaches - by OZ4 - 01-08-2016, 07:25 PM
RE: Philco 89B headaches - by sparkydave - 01-10-2016, 12:33 PM
RE: Philco 89B headaches - by sparkydave - 01-10-2016, 02:12 PM
RE: Philco 89B headaches - by klondike98 - 01-10-2016, 02:42 PM
RE: Philco 89B headaches - by AI2V - 01-13-2016, 04:48 PM
There are currently 6667 online users. [Complete List]
» 2 Member(s) | 6665 Guest(s)
