Starting restore on 118 cathedral
More pics, I am guessing that the grill cloth is original so will have to fine something close or use a deferent pattern of some kind, any suggestions? Icon_think Icon_think Icon_think Icon_think . The speaker also is a real mess, was caked with mud dabbers and coil is open, trans I think is shot and cone is shot with open voice coil, there goes 150$ for parts replacement and repair will consist  of bead blast speaker frame and paint and put all together , it will be worth it having a restored k-12 speaker for this monster 8 tube cathedral
RE: Starting restore on 118 cathedral - by Fred Taylor - 01-10-2016, 09:17 PM
RE: Starting restore on 118 cathedral - by Arran - 01-11-2016, 04:09 AM
RE: Starting restore on 118 cathedral - by SteveG - 01-13-2016, 12:57 AM
RE: Starting restore on 118 cathedral - by Arran - 01-13-2016, 02:47 AM
RE: Starting restore on 118 cathedral - by SteveG - 01-13-2016, 03:25 PM
There are currently 9962 online users. [Complete List]
» 2 Member(s) | 9960 Guest(s)
