Philco 47-1230 low audio
YEE HAW!!
OK, now there's audio! Many thanks for all of the help. I figured it'd be just as easy to replace all the coupling caps in 1st and 2nd audio stages, rather than testing them all first - plus, it might avoid headaches later on. I used ceramic type rated 3 kv - I hope they're OK for this application. I found correct values for the .003 mf, but was unable to find .006 mf - I don't think that's a standard value now - used .005 instead. I hope that's OK. At any rate, next step is an alignment, but I can see light at the end of the tunnel (it's not a train). Thanks a million!
Until next time,
Stirling KC0NXM.
Philco 47-1230 low audio - by hollowstate - 04-20-2009, 10:14 PM
Re: Philco 47-1230 low audio - by codefox1 - 04-21-2009, 09:01 AM
Re: Philco 47-1230 low audio - by NV3G - 04-21-2009, 10:28 AM
Re: Philco 47-1230 low audio - by hollowstate - 04-21-2009, 01:38 PM
Re: Philco 47-1230 low audio - by hollowstate - 04-23-2009, 11:56 PM
Re: Philco 47-1230 low audio - by codefox1 - 04-24-2009, 12:40 AM
Re: Philco 47-1230 low audio - by hollowstate - 04-25-2009, 06:43 PM
There are currently 8950 online users. [Complete List]
» 3 Member(s) | 8947 Guest(s)
