Philco 37-665B Restoration
Tubes tested first. Most caps replaced second. I'm still missing some parts but I'm hopeful they can be procured. Next will be the tube replacement, installation of replacement parts then, hopefully, a tune-up. This is the first time I've had a radio like this repaired and it's not a small undertaking to me. I look forward to her being brought home and placing her in a place of honor.
Philco 37-665B Restoration - by titan1a - 12-13-2015, 10:12 PM
RE: Philco 37-665B Restoration - by mikethedruid - 12-14-2015, 12:06 AM
RE: Philco 37-665B Restoration - by Arran - 12-14-2015, 01:52 AM
RE: Philco 37-665B Restoration - by klondike98 - 12-16-2015, 09:36 AM
RE: Philco 37-665B Restoration - by titan1a - 12-21-2015, 08:00 PM
RE: Philco 37-665B Restoration - by titan1a - 12-29-2015, 09:59 PM
RE: Philco 37-665B Restoration - by klondike98 - 12-29-2015, 10:23 PM
RE: Philco 37-665B Restoration - by titan1a - 12-30-2015, 01:11 AM
RE: Philco 37-665B Restoration - by klondike98 - 12-30-2015, 03:29 PM
RE: Philco 37-665B Restoration - by titan1a - 12-30-2015, 05:33 PM
RE: Philco 37-665B Restoration - by Eliot Ness - 12-31-2015, 11:32 AM
RE: Philco 37-665B Restoration - by klondike98 - 12-31-2015, 11:15 AM
RE: Philco 37-665B Restoration - by sam - 12-31-2015, 01:12 PM
RE: Philco 37-665B Restoration - by titan1a - 01-02-2016, 01:18 AM
RE: Philco 37-665B Restoration - by Arran - 01-02-2016, 02:40 AM
RE: Philco 37-665B Restoration - by titan1a - 01-02-2016, 09:39 PM
RE: Philco 37-665B Restoration - by mikethedruid - 01-04-2016, 10:24 PM
RE: Philco 37-665B Restoration - by titan1a - 01-05-2016, 12:46 AM
RE: Philco 37-665B Restoration - by titan1a - 01-05-2016, 12:10 PM
RE: Philco 37-665B Restoration - by mikethedruid - 01-05-2016, 04:31 PM
RE: Philco 37-665B Restoration - by titan1a - 01-14-2016, 03:05 AM
RE: Philco 37-665B Restoration - by sam - 01-14-2016, 04:04 AM
RE: Philco 37-665B Restoration - by titan1a - 01-14-2016, 04:42 PM
RE: Philco 37-665B Restoration - by titan1a - 01-18-2016, 12:48 AM
RE: Philco 37-665B Restoration - by mikethedruid - 01-18-2016, 01:41 AM
RE: Philco 37-665B Restoration - by Eliot Ness - 01-18-2016, 03:30 PM
RE: Philco 37-665B Restoration - by titan1a - 01-19-2016, 10:33 PM
RE: Philco 37-665B Restoration - by titan1a - 01-23-2016, 11:03 PM
RE: Philco 37-665B Restoration - by titan1a - 01-30-2016, 02:52 AM
RE: Philco 37-665B Restoration - by titan1a - 02-03-2016, 02:47 AM
RE: Philco 37-665B Restoration - by Arran - 02-05-2016, 02:06 AM
RE: Philco 37-665B Restoration - by titan1a - 02-14-2016, 11:29 PM
RE: Philco 37-665B Restoration - by titan1a - 02-22-2016, 11:18 PM
RE: Philco 37-665B Restoration - by titan1a - 02-28-2016, 12:01 AM
RE: Philco 37-665B Restoration - by klondike98 - 02-28-2016, 08:33 AM
RE: Philco 37-665B Restoration - by titan1a - 02-28-2016, 07:49 PM
RE: Philco 37-665B Restoration - by Mondial - 02-28-2016, 09:38 PM
RE: Philco 37-665B Restoration - by titan1a - 03-14-2016, 03:39 AM
RE: Philco 37-665B Restoration - by Fred Taylor - 03-14-2016, 07:26 AM
RE: Philco 37-665B Restoration - by titan1a - 04-03-2016, 03:12 PM
RE: Philco 37-665B Restoration - by titan1a - 04-04-2016, 12:50 AM
RE: Philco 37-665B Restoration - by klondike98 - 04-04-2016, 01:01 PM
RE: Philco 37-665B Restoration - by titan1a - 05-08-2016, 09:04 PM
RE: Philco 37-665B Restoration - by Mondial - 05-08-2016, 11:40 PM
RE: Philco 37-665B Restoration - by titan1a - 06-05-2016, 06:45 PM
Seen the light? - by titan1a - 12-16-2015, 01:40 AM
RE: Seen the light? - by mikethedruid - 12-16-2015, 02:59 AM
