Crosley 5-50
That is wonderful news. In case you need it, here is what I believe to be the schematic for the set, or a very similar Crosley model.
Crosley schematic
For greater output from the final audio stage a 71A was often used as the final AF amp instead of an 01A. Good luck with your work on this beautiful radio.
Crosley 5-50 - by Groundhog74 - 01-10-2016, 06:54 PM
RE: Crosley 5-50 - by Groundhog74 - 01-10-2016, 06:55 PM
RE: Crosley 5-50 - by mikethedruid - 01-10-2016, 07:38 PM
RE: Crosley 5-50 - by Jayce - 01-10-2016, 07:41 PM
RE: Crosley 5-50 - by Arran - 01-12-2016, 03:21 AM
RE: Crosley 5-50 - by Groundhog74 - 01-14-2016, 04:28 PM
RE: Crosley 5-50 - by titan1a - 01-14-2016, 04:44 PM
RE: Crosley 5-50 - by mikethedruid - 01-14-2016, 06:57 PM
RE: Crosley 5-50 - by Groundhog74 - 01-14-2016, 09:37 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7191 online users. [Complete List]
» 4 Member(s) | 7187 Guest(s)
AvatarAvatarAvatarAvatar
