Philco 90 - bottom cabinet moulding replacement?
I was about to do the same. I did this for a 70, Steve sells it directly or on eBay.
I gave the kit to Kirk, he did the rest.
RE: Philco 90 - bottom cabinet moulding replacement? - by morzh - 01-16-2016, 01:12 PM
There are currently 10836 online users. [Complete List]
» 2 Member(s) | 10834 Guest(s)
