My Next Project: Log Cabin
Regarding my bulb question:
(1)  I had the part numbers from the service documentation.
(2)  I visited “parts values” on the Philco Repair Bench.
(3)  The answer is:
[Image: https://lh3.googleusercontent.com/-399d7...520790.jpg]
Since the “special flat filament” bulb is not available, I made a reproduction:
[Image: https://lh3.googleusercontent.com/-6TfVk...520791.JPG]
The only high-temperature paint I had was “wrinkle coat,” which doesn’t cover well with a thin coat.  Flat black automotive or barbeque grill high-temperature paint will work better.
My Next Project: Log Cabin - by Winky Dink - 12-12-2015, 11:59 PM
RE: My Next Project: Log Cabin - by 462ron - 12-13-2015, 04:06 PM
RE: My Next Project: Log Cabin - by Winky Dink - 12-13-2015, 07:54 PM
RE: My Next Project: Log Cabin - by mikethedruid - 12-14-2015, 02:10 AM
RE: My Next Project: Log Cabin - by Winky Dink - 01-11-2016, 05:59 PM
RE: My Next Project: Log Cabin - by codefox1 - 01-14-2016, 03:50 PM
RE: My Next Project: Log Cabin - by Winky Dink - 01-15-2016, 12:35 AM
RE: My Next Project: Log Cabin - by Winky Dink - 01-16-2016, 07:20 PM
RE: My Next Project: Log Cabin - by Winky Dink - 01-28-2016, 08:18 PM
RE: My Next Project: Log Cabin - by mikethedruid - 01-28-2016, 08:32 PM
RE: My Next Project: Log Cabin - by Winky Dink - 01-28-2016, 10:07 PM
RE: My Next Project: Log Cabin - by Winky Dink - 01-29-2016, 01:52 AM
RE: My Next Project: Log Cabin - by mikethedruid - 01-29-2016, 02:21 AM
RE: My Next Project: Log Cabin - by Arran - 01-29-2016, 05:53 AM
RE: My Next Project: Log Cabin - by TV MAN - 01-29-2016, 02:33 PM
RE: My Next Project: Log Cabin - by Winky Dink - 02-01-2016, 03:58 AM
RE: My Next Project: Log Cabin - by mikethedruid - 02-01-2016, 04:23 AM
RE: My Next Project: Log Cabin - by Eliot Ness - 02-01-2016, 10:16 AM
RE: My Next Project: Log Cabin - by Winky Dink - 02-01-2016, 01:53 PM
RE: My Next Project: Log Cabin - by Winky Dink - 02-03-2016, 04:58 AM
RE: My Next Project: Log Cabin - by Eliot Ness - 02-03-2016, 09:34 PM
There are currently 6375 online users. [Complete List]
» 2 Member(s) | 6373 Guest(s)
