42-380x chassis questions
Hi Ron and welcome,
I can't quite tell what is broken but the general answer is yes. If the coil has a slug in it you may want to remove it just in case. Careful application of super glue should do the trick.
I don't see any notations in regards to the spkr plug. Just the wire color for the output transformer.
42-380x chassis questions - by lutemake3 - 01-16-2016, 12:50 PM
RE: 42-380x chassis questions - by Radioroslyn - 01-16-2016, 09:36 PM
RE: 42-380x chassis questions - by lutemake3 - 01-16-2016, 10:28 PM
There are currently 6696 online users. [Complete List]
» 2 Member(s) | 6694 Guest(s)
