Starting restore on 118 cathedral
Wow Fred - that cabinet looks simply amazing!
Incredible job. My 118 will need to be refinished at some point and I would be proud if it looks half as good as yours!
RE: Starting restore on 118 cathedral - by Arran - 01-11-2016, 04:09 AM
RE: Starting restore on 118 cathedral - by SteveG - 01-13-2016, 12:57 AM
RE: Starting restore on 118 cathedral - by Arran - 01-13-2016, 02:47 AM
RE: Starting restore on 118 cathedral - by SteveG - 01-13-2016, 03:25 PM
RE: Starting restore on 118 cathedral - by Nathan Slingerland - 01-17-2016, 08:26 PM
There are currently 9818 online users. [Complete List]
» 1 Member(s) | 9817 Guest(s)
