38-116 needs Dr. Philco.Resolved.
Murf
I am not sure what you mean by schematics don't apply, but if your tester (provided you trust it, and do so for a reason) shows shorts, well, you need to see what would happen if you tried known good tubes. BTW shorts might lower some voltage readings....sometimes all the way to zero.
38-116 needs Dr. Philco.Resolved. - by murf - 01-17-2016, 06:05 PM
RE: 38-116 needs Dr. Philco - by morzh - 01-17-2016, 07:08 PM
RE: 38-116 needs Dr. Philco - by murf - 01-17-2016, 08:37 PM
RE: 38-116 needs Dr. Philco - by morzh - 01-17-2016, 08:53 PM
RE: 38-116 needs Dr. Philco - by murf - 01-17-2016, 10:15 PM
RE: 38-116 needs Dr. Philco - by morzh - 01-17-2016, 10:57 PM
RE: 38-116 needs Dr. Philco - by murf - 01-19-2016, 05:02 PM
RE: 38-116 needs Dr. Philco - by morzh - 01-19-2016, 11:11 PM
RE: 38-116 needs Dr. Philco - by murf - 01-20-2016, 05:15 PM
RE: 38-116 needs Dr. Philco - by AI2V - 01-21-2016, 03:18 PM
RE: 38-116 needs Dr. Philco - by murf - 01-23-2016, 01:00 PM
RE: 38-116 needs Dr. Philco - by murf - 01-31-2016, 11:05 AM
RE: 38-116 needs Dr. Philco - by morzh - 01-31-2016, 11:57 AM
There are currently 6722 online users. [Complete List]
» 2 Member(s) | 6720 Guest(s)
