philco 48-1283 wiring issue
jtkmsms, reverse the wires on the on/off switch! PL
philco 48-1283 wiring issue - by Guest - 04-24-2009, 05:31 PM
Re: philco 48-1283 wiring issue - by planigan - 04-24-2009, 11:34 PM
Re: philco 48-1283 wiring issue - by Texasrocker - 04-25-2009, 03:52 AM
Re: philco 48-1283 wiring issue - by Guest - 04-25-2009, 10:06 AM
Re: philco 48-1283 wiring issue - by codefox1 - 04-25-2009, 01:23 PM
Re: philco 48-1283 wiring issue - by planigan - 04-25-2009, 08:12 PM
Re: philco 48-1283 wiring issue - by Guest - 04-26-2009, 12:07 AM
Re: philco 48-1283 wiring issue - by planigan - 04-26-2009, 01:36 PM
Re: philco 48-1283 wiring issue - by planigan - 04-26-2009, 01:52 PM
Re: philco 48-1283 wiring issue - by Guest - 04-26-2009, 04:45 PM
Re: philco 48-1283 wiring issue - by planigan - 04-26-2009, 06:47 PM
Re: philco 48-1283 wiring issue - by planigan - 04-26-2009, 11:10 PM
Re: philco 48-1283 wiring issue - by Guest - 05-03-2009, 12:43 AM
Re: philco 48-1283 phono cartridge replacement - by Guest - 05-06-2009, 04:36 PM
Re: philco 48-1283 wiring issue - by Bob - 05-06-2009, 08:41 PM
Re: philco 48-1283 wiring issue - by planigan - 05-08-2009, 01:13 AM
There are currently 7615 online users. [Complete List]
» 1 Member(s) | 7614 Guest(s)
