Unknown Gilfillan Model
I have done some research, and have not been able to ID the model on this yet. I do know it is made by Gilfillan, which was a small, Los Angeles manufacturer. It has 4 tubes, 47, 57, 58, and 80. I tried doing a tube search on Radio Museum, to no avail. I suspect one of the tubes may be a substitute, but I'm not sure.
Here's some more pics of it once I got it home.
[Image: https://farm5.staticflickr.com/4308/3503...f082_b.jpg]
[Image: https://farm5.staticflickr.com/4286/3506...3f02_b.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:22 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:29 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:34 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:45 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:52 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 01-19-2016, 02:57 AM
RE: Unknown Gilfillan Model - by mikethedruid - 01-19-2016, 05:13 AM
RE: Unknown Gilfillan Model - by Arran - 01-19-2016, 05:41 AM
RE: Unknown Gilfillan Model - by Eliot Ness - 01-19-2016, 08:53 PM
RE: Unknown Gilfillan Model - by Paul Philco322 - 01-19-2016, 09:52 PM
RE: Unknown Gilfillan Model - by Arran - 01-20-2016, 02:58 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:03 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:07 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:19 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:20 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 01:24 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 09-11-2016, 02:29 AM
RE: Unknown Gilfillan Model - by OldRestorer - 09-11-2016, 08:10 AM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 07-12-2017, 12:59 AM
RE: Unknown Gilfillan Model - by OldRestorer - 07-12-2017, 11:30 AM
RE: Unknown Gilfillan Model - by Eliot Ness - 07-12-2017, 01:42 PM
RE: Unknown Gilfillan Model - by PhilcoPhan1936 - 07-13-2017, 02:11 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6163 online users. [Complete List]
» 1 Member(s) | 6162 Guest(s)
