38-116 needs Dr. Philco.Resolved.
New tube helped a lot.
Also , seems there was a resistor out of place and I found a .1 cap installed where there was supposed to be a .01.
Volume is much better now.
Just need to get the bass response working better and I will call it good.
Checked tube bias tonite and looks great on both 6l6 tubes.
Will continue to poke around.
murf
38-116 needs Dr. Philco.Resolved. - by murf - 01-17-2016, 06:05 PM
RE: 38-116 needs Dr. Philco - by morzh - 01-17-2016, 07:08 PM
RE: 38-116 needs Dr. Philco - by murf - 01-17-2016, 08:37 PM
RE: 38-116 needs Dr. Philco - by morzh - 01-17-2016, 08:53 PM
RE: 38-116 needs Dr. Philco - by murf - 01-17-2016, 10:15 PM
RE: 38-116 needs Dr. Philco - by morzh - 01-17-2016, 10:57 PM
RE: 38-116 needs Dr. Philco - by murf - 01-19-2016, 05:02 PM
RE: 38-116 needs Dr. Philco - by morzh - 01-19-2016, 11:11 PM
RE: 38-116 needs Dr. Philco - by murf - 01-20-2016, 05:15 PM
RE: 38-116 needs Dr. Philco - by AI2V - 01-21-2016, 03:18 PM
RE: 38-116 needs Dr. Philco - by murf - 01-23-2016, 01:00 PM
RE: 38-116 needs Dr. Philco - by murf - 01-31-2016, 11:05 AM
RE: 38-116 needs Dr. Philco - by morzh - 01-31-2016, 11:57 AM
There are currently 4568 online users. [Complete List]
» 1 Member(s) | 4567 Guest(s)
