Philco 39-6 question
I have a 39-6 here is the link
http://www.nostalgiaair.org/pagesbymodel...013300.pdf
The bakelite  cap # 29 is listed as .oo6 uf but the number on the side of the bakelite is #3615 OSU the chart I have shows it as 1 section  .05uf , what do I go with?
Eric
Philco 39-6 question - by Eric - 01-23-2016, 01:01 PM
RE: Philco 39-6 question - by morzh - 01-23-2016, 01:17 PM
RE: Philco 39-6 question - by Eric - 01-23-2016, 02:26 PM
RE: Philco 39-6 question - by Eric - 01-24-2016, 11:21 AM
RE: Philco 39-6 question - by KCMike - 01-24-2016, 02:20 PM
There are currently 6345 online users. [Complete List]
» 2 Member(s) | 6343 Guest(s)
