Starting restore on 118 cathedral
Here is the stains and toners used on the 118 cathedral. Any questions on these products and application please ask for best results. The buffcoat clear is whats on my 118 cathedral, if you want a little more gloss you can add a little piano or instrument lacquer to the buffcoat. If the high gloss piano or instrument lacquer is used , it must be wet sanded and buffed out for maximum results.
RE: Starting restore on 118 cathedral - by Arran - 01-11-2016, 04:09 AM
RE: Starting restore on 118 cathedral - by SteveG - 01-13-2016, 12:57 AM
RE: Starting restore on 118 cathedral - by Arran - 01-13-2016, 02:47 AM
RE: Starting restore on 118 cathedral - by SteveG - 01-13-2016, 03:25 PM
RE: Starting restore on 118 cathedral - by Fred Taylor - 01-23-2016, 11:15 PM
There are currently 9847 online users. [Complete List]
» 1 Member(s) | 9846 Guest(s)
