Starting restore on 118 cathedral
Really helpful - thank you for the pictures!
OK - here goes...
  • The part I'm most curious about is how do you apply the sealer and clear lacquer?
  • For the grain filler step, which one do you use?
  • For the stain on the main part of the cabinet are you applying it with a cloth?
  • Did you need to sand between any of the steps?
This is my understanding of the overall process - does it any way reflect reality? Icon_e_smile
I tried matching up with the photos:
1. Strip
[2nd picture in post #1]
2. Grain fill
[4th picture in post #1]
2b. Sand (?)
3a. Stain
-Wiping Wood Stain 'Medium dark walnut' on everything except for front center and wings.
3b. Toner
-Ultra Classic Toner 'Golden Oak' on front center and wings
[2nd picture in post #9]
3c. Airbrush (blend/highlight)
-Wiping Wood Stain 'Extra dark walnut' used to tone front panel mini wings and center darker, fade on bottom moldings and arch
[4th picture in post #9]
4. Sealer
-E-Z Vinyl Sealer
5. Decals (?)
6. Clear lacquer
-Buffcote Lacquer (optionally mixed with Classic Instrument Lacquer)
<let dry a while>
7. Wet sand and buff out
-If using piano/instrument lacquer in Step #6
RE: Starting restore on 118 cathedral - by Arran - 01-11-2016, 04:09 AM
RE: Starting restore on 118 cathedral - by SteveG - 01-13-2016, 12:57 AM
RE: Starting restore on 118 cathedral - by Arran - 01-13-2016, 02:47 AM
RE: Starting restore on 118 cathedral - by SteveG - 01-13-2016, 03:25 PM
RE: Starting restore on 118 cathedral - by Nathan Slingerland - 01-24-2016, 01:31 PM
There are currently 9938 online users. [Complete List]
» 3 Member(s) | 9935 Guest(s)
