GE model 60 clock radio Static
(01-24-2016, 01:16 PM)OldRestorer Wrote:  I am not sure but I had SMD in my Halli and even if it was not and they were clean...If I had them open I would have replaced them. You cant always see the problem. Mine were ok in one but tainted in the other. Still replaced all 4 and now it will last another 70 years without issue.
 I am glad yours works now though. I am going to get one since I like clock radios and recently was given a great AD for one. I may go to the local Staples and have it scanned. If you ant a copy please let me know.
Kirk
Thanks I would, I have the white one also have the one on the bottom of the flyer
Eric
GE model 60 clock radio Static - by Eric - 10-27-2015, 04:50 PM
RE: GE model 60 clock radio Static - by Eric - 10-28-2015, 10:13 AM
RE: GE model 60 clock radio Static - by Eric - 10-28-2015, 07:16 PM
RE: GE model 60 clock radio Static - by David - 11-01-2015, 06:43 PM
RE: GE model 60 clock radio Static - by Eric - 11-03-2015, 08:46 PM
RE: GE model 60 clock radio Static - by David - 11-04-2015, 09:06 AM
RE: GE model 60 clock radio Static - by codefox1 - 11-26-2015, 02:18 PM
RE: GE model 60 clock radio Static - by TV MAN - 12-16-2015, 10:35 AM
RE: GE model 60 clock radio Static - by Arran - 12-17-2015, 05:13 AM
RE: GE model 60 clock radio Static - by Eric - 01-24-2016, 12:03 PM
RE: GE model 60 clock radio Static - by Eric - 01-24-2016, 05:30 PM
RE: GE model 60 clock radio Static - by TV MAN - 03-02-2016, 02:41 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
There are currently 4062 online users. [Complete List]
» 2 Member(s) | 4060 Guest(s)
