Philco 81 B Dial replacement
        Well,,,,Mark Oppat says that he does NOT have thee dial with the S.W. numbers under the scale,---he has 27-5009 and B-7989 ,,and Radio Daze only has B-7989,,,soo,,,I must have B-7989 ---ALSO (my mistake on number before) ,,, So I presume that the one  ,,,that I would need  would be the B-7889,,,which I can not find,,,
RE: Philco 81 B Dial replacement - by Ron Ramirez - 01-23-2016, 04:12 PM
RE: Philco 81 B Dial replacement - by Radioroslyn - 01-25-2016, 04:36 PM
RE: Philco 81 B Dial replacement - by Kenneth F. Besso Jr. - 01-26-2016, 07:55 PM
There are currently 5871 online users. [Complete List]
» 1 Member(s) | 5870 Guest(s)
