Model 90 Tuning after cleaning tuning capacitor
Rich, Looking at the picture, it appears, the first plate toward the shaft is bent. If it was that way when it was assembled, it would cause a short.
On another note. Your condenser is a three gang. That indicates you have a late version 90. These are not very common.
M R Radios   C M Tubes
RE: Model 90 Tuning after cleaning tuning capacitor - by Steve Davis - 01-26-2016, 09:49 PM
There are currently 6724 online users. [Complete List]
» 2 Member(s) | 6722 Guest(s)
